N4TECguy
I think your dealer is wrong, I am fairly certain alignment is covered under the "adjustments" clause for 1 year 12K miles. That is basically industry standard and I'm fairly certain I've read that on these forums too.
At this point I think everybody is looking the wrong direction. Alignments are simple and it's been on two rigs already, a third would confirm who's right like you said. But IMO, you don't have an alignment problem. Alignment problems typically manifest themselves at steady state cruising, and aren't usually magnified by throttle (except maybe if caster is out of whack). Neither will a brake issue be magnified by throttle, or by popping it into neutral. I think the problem you have is suspension related.
Couple of years ago I was at Willow Springs, they were holding drag races. This highly modified Civic Wagovan pulled up and being a unique car for drag racing, I was taking pictures of it. As I was snapping pictures I realized his front wheels would actually severely toe-out when he was on the throttle, and then snap back to straight when he went to shift gears. I asked a couple folks to look for it on his second run and they all saw it too. I think that's what you need to be looking for, something loose on one side of the car. Maybe have someone driving next to you when you apply throttle (obviously everyone needs to be careful here since we know the car wants to change lanes), and look for the passenger side wheel to turn but the driver side to keep going straight ahead. If you had easy access to a dyno it might be easy to go that way, but I know practically nobody has easy access to a dyno. Could be something like a worn out ball joint? That would be easy to check, just by putting the wheels in the air and yanking at the tires. Just something to think about.
