CATDI
Hi All:
Thought I'd let the TDI family know that the tandem pump on my 2006 BRM with 96K miles died. It warned us somewhat, but I thought it was a weak battery causing the issue and not the pump.
More information for those who run across the thread...
Car: 2006 Jetta TDI (BRM engine with 96K miles)
Problem: Car wouldn't start. It would turn over fine, but simply wouldn't start and run.
Symptoms: Prior to the complete start failure, sometimes the car wouldn't start right away after making several trips around the city. Usually waiting a couple of minutes between cranking would get it to fire. When started, car would act fine.
Checked: ASV- OK. Lift Pump- OK. Tandem return hose- erratic flow.
Actions: Replaced fuel filter and J329 relay. Didn't help.
Solution: Replace tandem pump. No problems after replacement.
Extra info: According to the mechanic, the tandem pump was bad and allowing air into the fuel system and causing "loss of prime". He was eventually able to get it to start by allowing it to turn over for 30 secs. My battery was weak, so I was unable to do that in my driveway during my testing.
IMHO, If you have a BRM that is starting to "get hard to start" after many trips around town, or when you first start in the morning, that may be a sign that your tandem pump is going out if your lift pump is ok and your ASV is ok.
Hope this helps someone.
-Ed
-Ed
