thatvwguy
Could you be more specifc...mrGutWrench said:I just don't like how the oversided tires work on my car
Did you change the ring a pinion gear in the transaxel to keep the same power curve? Just curious.Old thread but it helped me. For anyone searching for info on fitting larger tires on your jetta/golf, this should help!
Here is my 03 mk4 station wagon with 205/70/15 installed all around. 1" ground clearance gained which has made a huge difference! No rubbing. better mpg. win win win.
https://youtu.be/Vul_Uouupl8
I also have an '03 Jetta wagon that came with oversized Michelin winter tires. The circumference is greater, of course, and now the speedometer is nearly actual instead of showing about 3 mph greater than actual. I figure that the distance traveled is about 1.5% further than reflected in the odometer reading, so to get an actual mpg requires an adjustment.Old thread but it helped me. For anyone searching for info on fitting larger tires on your jetta/golf, this should help!
with 16" on my car it reads high, with 17" it reads low. both are factory sizes. and rollout of the tire changes as the tire wears. unless the car uses gps for speed and miles its not possible to be 100% accurate all the time.I own an 06 Jetta TDI. I noticed that my Speedometer is 3 or 4 Miles off what it should be IE: If I'm going down the road 75 I'm really going just a little over 70. This is a fact that I am guessing many of you are familiar with. (VW even admited they knew about it)
Here is the question....
I have 205/55/16's on the TDI. Can anyone tell me if it would be a good or bad idea to go to a 205/65/16? This makes about a 3.9 mile an hour difference according to this tire size web site which would make me closer to correct on the speedometer and odometer, and would this not also show better fuel economy? (less revolutions per mile)
http://www.miata.net/garage/tirecalc.html
I have called a few places (including VW) and they said the only thing they can think of that would come into play would be the ABS.
Any thoughts?
I went from a 55 profile to a 65 profile... taller tires will have the affect of lowering the indicated speed of the vehicle, for a given speedometer. How could it be otherwise?Doesn't bother me any, I see it as cheap insurance against radar traps.
I'm surprised you found the 206/65R15 to correct the speedo - that's not been my experience personally, mine still reads about 5mph high at 65 (indicated) on my 2002 Jetta.
