turbotorq
Battery voltage is 12.6v
Idling voltage is 13.5v
Idling while using all possible amp drawing settings, voltage drops to 12.4 and jumps back up to 13 then drops again.
Should alternator keep above 13.5v's at idle even when using headlights heated seats radio etc?
My original symptoms was dead battery, but after my battery charger reading "fully charged" after only 30 mins of charging, I assumed my problem was starter. Pulled starter off my ALH parts car, exact same problem. Pulled murano battery, threw it in BEW, VVVOUURRMM….. is my alternator killing my 790cca battery?
