PeeWee
Let us know how this works for you once you get the mount installed!
transfer box is splined to differential carrier (it's input is front wheel speed), and all transfer boxes are the same ratio, I believeI am currently in the process of partially rebuilding/strengthening my diesel gearbox and putting it back into my Jetta. I will be opening up the gearbox and adding a vw mk6 R AWD diff in it with ARP bolts, bronze sliders, 02Q 4th gear input shaft support and diff bearing and seal kit. My question here is, currently on my car I am using a VW MK5 R32 rear diff, will the diesel gearbox ratios be in conflict with the petrol rear diff?
Or is the mk5 Golf 4motion diesel rear diff the same as the mk5 r32 petrol rear diff?
turbo seals are steel rings, no drying up that can be doneMaybe seals dried up from not being used.
What a lovely stack you have there.........Gearbox modding time. I will be installing a 2nd hand AWD diff (out of a 02q golf mk6 R gearbox) using ARP bolts to secure it into place, and I will also be adding steel forks, bronze sliders and the 4th gear support bracket. The diff will be installed tomorrow and I am waiting for the steel forks to arrive sometime next week.
I was thinking of going for a LSD diff for the front, though it would defeat the purpose of my AWD conversion as most power would be back at the front wheels. I'm currently looking for a rear LSD diff which is compatible for a mk5 R32 rear diff. I believe this should allow for more power to be used at the rear wheels.
Sent from my Pixel XL using Tapatalk
The CHRA was already balanced when I received it. I just pulled the old CHRA out and installed the new one.Did you balance the turbo after cw install or just put it on ?
Please explain the reasoning behind this.
Hello TDIMeister, please correct me if I'm wrong. If a solid and hollow shaft have the same outside diameter, the solid shaft will have more torsional resistance than the hollow shaft. One of the reasons of the shaft being hollow is to reduce mass. For a hollow shaft to carry similar torsional loads, its diameter needs to be increased. Therefore, if you compare a solid and hollow shaft that weigh the same, then the hollow shaft should be stronger because of the increased OD (providing its not too thin in wall thickness, making it act in a slender manner).Please explain the reasoning behind this.
Nice, do you have a link for your build so I can check it out?I have similar parts on my build but I have 3" exhaust, CP3 pump and water injection. Built everything from a friend who sold his A3 back to VW.
Thanks!Nice build!
I thought the input shaft support bracket wouldn't be needed if adding a solid insert instead?? I just recently had my gearbox apart, and sort of shaking my head now that I did not opt for the insert or support bracket. Aiming for north of 400ft-lbs with my build.
Thank you for your kind wordsGreat job you are doing. I am sure other MK5 owners like me appreciate all the information you are giving based on your learning experience. If this question has been asked, please excuse me. I missed it. How much modifications were needed to put the MK6 R front bumper on the MK5? I need to replace my stock one and I like what you have done. Great effort on your build.
What he said. Plus I will add:your idea behind the solid shaft doesn't work at all. It will have little to no effect on your strength. Unless you happened to friction weld the two pieces to create a solid member. Also the hollow shaft is most likely induction hardened while your solid billet aluminum is not. Leaving most of the strength in the hollow shaft. This would be similar to putting a hot dog in a steel tube and bending it then saying the hot dog made it stronger. Technically yes but so minuscule that it makes no difference.
