merkin
Rebuild top end, after putting everything back together as per bently, and timing belt procedure here. I was unable to turn engine over manually. Seemed like the tb was getting stopped at the injector pump. Is it possible for this to seize? 2000 Jetta TDI. Thanks for any info.
I removed the tb turned the crankshaft back 90 degrees from tdc and was able to turn camshaft.
