cryptologic
So just bought a 2014 Passat TDI SE in January. Nothing but problems so far honestly. Heater core no good (VW fixing that at least), just replaced water pump and all associated parts (timing belt, etc). Right before the leaking water pump started I suddenly got a bunch of warning lights on the dash.
I get (all in amber) ABS, ESC, steering, low tire, and airbag. Started out with a blinking low tire then solid. Checked tire pressures. They were fine. Restarted car, light went out. A few days later the ABS, ESC, and steering starting randomly coming on along with the low tire pressure light. Now they are just on and wont go off at all. Did some research on the forum and a failing battery sometimes causes this. Had a VW battery (might even have been the original). It tested fine but I replaced it anyway. All the lights still on all the time.
Any ideas? Is it maybe just a bad wheel speed sensor? My cheap bluetooth ODB and Torque don't show any codes.
Thanks,
Crypto
Thanks,
Crypto
