Old January 29th, 2013, 20:06   #1
2micron
TDI(s): None
Default 2microntech - Helping to Keep Your Common Rail VW Alive!!
2micron is offline   Reply With Quote
Old January 29th, 2013, 20:08   #2
2micron
TDI(s): None
Default “Pure Flow” HPFP Adapter.
Old January 29th, 2013, 20:09   #3
2micron
TDI(s): None
Default “Drain Flow” Intercooler Kit.
Old January 29th, 2013, 21:31   #4
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
PM Sent
update 10/22/2013: I have been running the contain rev.1, and now the new 1 micron contain rev.2 since february 2013. I'm pushing the limits of the CR140 design with 234WHP and 404WTQ, this is top quality insurance for the abuse I am putting the fuel system through. I've been running the pure-flo since before its release, with no issues with the kit. I'll be upgrading the factory CP4.1 fuel pump to a 4.2 to meet the demands of what my engine needs and continue to run both.
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old January 30th, 2013, 09:52   #5
red64chevelle
For anybody sitting on the fence, Andrew is the only one keeping me in my CR VW. Great products that are thought out much better than the OEM.
Current: 2012 Golf R, 1986 Land Rover Defender 110 with 300TDI
Past: 84 Rabbit GTI, 84 Jetta TD, 87 Cabby, 92 Jetta ECODiesel, 92 Cabby, 99 Beetle TDI, 03 Jetta TDI, 06 Passat 3.6 4motion, 11 Golf TDI, 02 Golf TDI
red64chevelle is offline   Reply With Quote
Old February 5th, 2013, 05:22   #6
2micron
TDI(s): None
Contain Flow return filter update. Sorry folks.
I greatly apologize.
Recent discussion has raised concerns that the 5 micron filters used in this kit are not suitable to contain the Sub Micron particles, created after an HPFP failure.
No more kits will be sold at this time. A better filter will be sourced and flow tested to help satisfy the concerns raised by our great club members!
Sorry to all.
Thanks for the understanding,
Andrew
Old February 5th, 2013, 17:55   #7
schultp
schultp's Avatar
I am saddened by your decision but understand. For everyone else, Andrew is an upstanding individual and really cares about helping others. Andrew has been extremely diligent in thinking out the process of testing and developing add-ons that would reduce the damage of a catastrophic HPFP failure. Certainly, he is not able to afford to mimic the failure in a controlled test setting. But, his add-ons have been tested and shown to not pose a risk IMHO. Please continue to encourage Andrew to continue his great work for all of us.
I'd like to openly say thank you to Andrew for everything he has done. Even if his products don't continue to be developed.
Paul.
2010 JSW TDI, 6sp manual
schultp is offline   Reply With Quote
Old February 6th, 2013, 04:27   #8
nhdude
I'm thinking 5 microns is still better than no filtration. Hope your quest for a finer filter is successful and we see this great concept available to us again!
nhdude is offline   Reply With Quote
Old February 6th, 2013, 05:35   #9
wrpercival
wrpercival's Avatar
Fuel Economy: No complaints
Originally Posted by nhdude View Post
I'm thinking 5 microns is still better than no filtration. Hope your quest for a biner filter is successful and we see this great concept available to us again!
I agree. If the existing/stock filter is less efficient, doesn't that presume that there are already contaminants (dirt, etc) that are less than 5 microns in size that are passing through the entire system?
wrpercival is offline   Reply With Quote
Old February 6th, 2013, 05:37   #10
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Good point...
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old February 6th, 2013, 09:16   #11
JSWTDI09
JSWTDI09's Avatar
This is exactly the reason why I have no intention of removing my return filter. It will stay in my car - at least until 2micron comes up with a better design.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old February 6th, 2013, 10:01   #12
whatnxt
whatnxt's Avatar
Fuel Economy: 30-36
The ALHs and PDs run a CAT (2 micron) or a 1 micron filter as an upgrade to the OEM filter with no issues. Why would running one of these "type" be an issue with the CR?
As has been said, even at 5 micron, this is an improvement.
That that is, is. That that is not, is not.
'17 Mk VII GSW 4Motion, white-current
'12 Mk VI Golf TDI w/tech-returned
'15 BMW 328d Xdrive, sapphire black, Sport -returned
whatnxt is offline   Reply With Quote
Old February 6th, 2013, 11:19   #13
JSWTDI09
JSWTDI09's Avatar
IF (big if) the problem is sub-micron particles, even a 1 micron filter might not be enough. Our biggest problem is how little we really know about the number and size of contaminate particles. We are forced to do some guessing here.
Have Fun!
Don
Old February 6th, 2013, 12:35   #14
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I'm waiting on the IC drain kit. Seems like this would be the easiest to install and the least noticable when I get service done.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old February 6th, 2013, 12:52   #15
JSWTDI09
JSWTDI09's Avatar
I'm waiting for that too. However, I'm lucky, so this is a low priority. Where I live moisture (in any form) is pretty rare. There is not much condensation when the relative humidity is measured in single digits. People here consider 30% humidity to be "muggy". They have no idea what muggy really feels like (I lived for several years in Louisiana). Also there is no issue with freezing when the temperature in my garage rarely goes below 50 degrees F. at night and daytime temps are always above freezing.
Not only would is be the least noticeable, but it would also probably be the least objectionable to a dealer.
Have Fun!
Don
Diesel Power Tuning Modules for VW Common Rail at kermaTDI VailPowder Vendor & GroupBuy items for sale 32 March 18th, 2015 18:18
VW utilisera un common rail en 2008? Nico3d3 Quebec 4 June 26th, 2007 17:41
Common Rail Drivbiwire TDI 101 1 June 23rd, 2006 07:15
VW move to Common Rail TDIdragon TDI News/Tech 81 June 12th, 2006 06:55
VW TDI common rail flappie VW MKIV-A4 TDIs (VE and PD) 77 May 25th, 2002 23:08
Page generated in 0.19445 seconds with 11 queries
[Output: 131.78 Kb. compressed to 109.48 Kb. by saving 22.30 Kb. (16.92%)]
