Old September 4th, 2017, 15:43   #1
suchshutterfly
suchshutterfly's Avatar
Fuel Economy: 44.8 avg 52.2 best
Default 2000 Golf factory alarm disarm/permanent disable
Now that I have pulled fuses 6 and 14 and disabled the horn for my alarm, has anyone been able to come up with a way to permanently disable the factory alarm in a MKIV without pulling those fuses permanently? I'd like to have my interior lights back (14) because seeing at night is nice. Also, I'm not sure what else I've disabled by pulling those fuses. VAG-COM can't disable it. It was only intermittently arming itself before by locking the door with the key (my fob, despite new batteries and testing OK using an RF scanner at Advance Auto, will not lock, unlock, or interact with the vehicle outside of physically starting the engine/locking/unlocking the doors). It armed last night and would not disarm until I pulled those fuses (I tried the open hatch trick, too, no luck).
My Golf is my business partner. Cute but tough.
You're half dude, aren't you?
suchshutterfly is offline   Reply With Quote
Old September 12th, 2017, 12:08   #2
suchshutterfly
Update: so, pulling fuses 6 and 14 disabled the alarm. I left them out for a few days but needed to open the windows because it got warm outside again so I put them back in. Henceforth, I will do things (like lock all four doors from the passenger's side, not by inserting the key into the driver's side door) that could potentially arm the alarm as little as possible in the hopes to never arm it again.
Old September 12th, 2017, 13:18   #3
steve6
why do you want to do this?
steve6 is offline   Reply With Quote
Old September 12th, 2017, 13:37   #4
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, why not just fix the car? The alarm is simply a component of the Central Convenience system, there is not really any extra "stuff" to it, aside from the little blinky light on the driver door and the little beepy horn in the cowl.
You likely have a bad door latch or something.
www.cardocautomotive.com
Old September 12th, 2017, 13:44   #5
BobnOH
Fuel Economy: 50/45/35
Try contacting Rocketchip in Red Lion PA. I think his name is Rick Robertson. Maybe you can drive over there and get it the way you need it.
Assuming you just want it disabled and there is not a problem with the alarm system.
Old September 13th, 2017, 12:19   #6
Rrusse11
It's Jeff. Try rocketchip.com, he's a one man show, so don't expect instantaneous response. Great tunes!, and knows these vehicles well.
RC Stage 4: 11mm pump, 17/22, 3bar MAP:2.5" Exhaust: Koni Reds HD Springs, ~1"lift:VR6 fr swaybar, Top strut & rear tie bar: XXIO Racing Rims, 215/55ZR16 GMax AS03's, 10mm/20mm spacers, 35# @: Ventectomy: Atlas skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: Bosal Hitch: VW racks:
Rrusse11 is offline   Reply With Quote
Old September 13th, 2017, 12:31   #7
Nevada_TDI
His handle here is "jsrmonster."
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Old September 14th, 2017, 14:50   #8
Rxfire
Rxfire's Avatar
See my posts here:
#2 here:
http://forums.tdiclub.com/showthread...ighlight=fuses
#3 here:
This will lead you to this thread:
http://forums.tdiclub.com/showthread...highlight=fuse
see my post at #15 within that thread
P.S. My buddy is still driving his 2000 Jetta that we did this to, with no issues
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
alarm will not disarm l2wboard TDI 101 6 June 16th, 2014 08:54
Can VCDS be used to disable "disarm/arm alarm w/key" and window roll up /down ? B.Lee OBD Scanners 4 February 13th, 2012 11:42
disable factory alarm with vagcom zaathur VW MKIV-A4 TDIs (VE and PD) 15 October 11th, 2011 20:15
remote not working. alarm won't disarm! movemint VW MKIV-A4 TDIs (VE and PD) 0 February 7th, 2005 07:38
Factory door lock Don't disable Car Alarm Just Some Guy Upgrades (non TDI Engine related) 9 April 2nd, 2002 11:06
Page generated in 0.13187 seconds with 13 queries
[Output: 89.37 Kb. compressed to 76.87 Kb. by saving 12.50 Kb. (13.98%)]
