Old September 13th, 2017, 11:47   #1
pedorro
pedorro's Avatar
Question Weeping/Seepage Near Left Rear Wheel
I noticed a spot on the driveway a few days after the car was parked. It has been parked for two weeks and the spot has not grown.
This is at the splash guard in front of the left rear wheel and appears to be coming from behind the guard and fender liner. There are no other signs of wetness or fluid travel on the undercarriage.
Any idea of its source? Blown shock maybe...?
2012 6MT with ~61K miles.
Thanks In Advance!
Lee
pedorro is offline   Reply With Quote
Old September 13th, 2017, 12:33   #2
VernK
That's in the area of a brake line connection. Have you had any brake work done recently?
Yours
Vern
VernK is offline   Reply With Quote
Old September 13th, 2017, 12:38   #3
pedorro
pedorro's Avatar
Yours
Vern
Thanks for the input Vern...that makes sense. No brake work of any sort has been performed to date.
Old September 14th, 2017, 05:33   #4
740GLE
drain plugs for sunroof? wait 6MT, no roof right?
Old September 14th, 2017, 08:35   #5
pedorro
pedorro's Avatar
Correct, no sunroof...and the fluid is viscous.
Old September 14th, 2017, 08:46   #6
tdiatlast
Extreme ambient heat, causing rust-proofing wax to migrate?
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is online now   Reply With Quote
Old September 14th, 2017, 08:58   #7
VernK
That does sound possible. I had wax leaking out of ours for a couple of summers after we bought it. And now that I look at the pic carefully, that surely looks like a drop of wax on the bottom of the mud flap.
Yours
Vern
Old September 14th, 2017, 09:04   #8
tdi54
Quite likely that's culprit.
tdi54 is offline   Reply With Quote
Old September 14th, 2017, 09:35   #9
tdiatlast
I'm thinking the stuff migrated gradually until the area in question just can't contain it. Maybe the car was parked for a few days, in direct sunlight on that side, and the stuff liquified and found a crevice.
Old September 14th, 2017, 10:38   #10
pedorro
pedorro's Avatar
That side of the car does face south and it was 100-106 for nearly a week running. The thin all-weather cover on it does nothing to protect from heat.
Thanks all for your input!
I'll drive more and worry less.
Left Rear Wheel Rattle hawkdriver TDI 101 0 August 26th, 2014 22:41
Emergency Brake - Rear Left Wheel issue? STRANGETDI TDI 101 3 April 15th, 2010 12:07
One more thing: ding on the left rear wheel well Octang Frye VW MKV-A5 Golf/Jettas 2 June 16th, 2008 09:47
ABS Left Rear Wheel Speed Sensor Intermittent Signal Fault Code Racer007 OBD Scanners 12 May 12th, 2008 14:57
wtb 1 2006 jetta aluminum wheel and left rear lower control arm falconslayer Private TDI Items for Sale/Wanted 0 January 2nd, 2008 17:29
Page generated in 0.15881 seconds with 13 queries
[Output: 95.84 Kb. compressed to 81.25 Kb. by saving 14.59 Kb. (15.22%)]
