Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old September 8th, 2017, 14:17   #1
StuMan
Default Where to buy a catalytic converter
Hi all, My Dad (78) has a 2006 TDI Jetta and he's moved to live with us. He had to go down to get an emissions test and found that he has no catalytic converter. From what I'm told and what I can find they all came with one so someone ripped him off at some point. I can't imagine why they'd take it except for scrap value?? Anyway, I guess we need to get him a new one. Any tips on where to get a deal? The dealership wants $1198!
Thanks!
StuMan is offline   Reply With Quote
Old September 8th, 2017, 14:20   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
A specialty exhaust shop will be able to install one for you. Make sure they know to install a diesel cat - different than one made for a gasoline car.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old September 10th, 2017, 15:33   #3
flee
Fuel Economy: 40-ish
Try to find out if they inspect for a VW (OEM) stock number stamped on the cat.
If so, a junkyard one can probably be found. If not, several exhaust suppliers sell them.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old September 12th, 2017, 20:44   #4
Rodmiser
Fuel Economy: 47 MPG last 10 tanks & 57 MPG BEST
Default newvwparts.com
1K0-254-508-G
Intermediate Pipe
Converter & Pipe
1.9 LITER
$1,198.00 was
$956.00 today
They ship FED-X ground
Rodmiser is offline   Reply With Quote
Old September 13th, 2017, 05:26   #5
oilhammer's Avatar
Fuel Economy: fantastic
Make sure the inspection station actually knows WHERE the catalyst is on the BRM. It is just a little oval pump in the down pipe right off the turbo, down underneath where many catalysts are there is nothing. They may just be unfamiliar with that car. You can see the top of the catalyst under the hood back by the firewall, the oxygen sensor screws into it.
www.cardocautomotive.com
Old September 15th, 2017, 15:23   #6
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
^This, right here.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
3-way Catalytic Converter GoremanX TDI Conversions 7 March 23rd, 2015 06:04
Best place to buy catalytic converter complete vwtdi1955 VW MKIV-A4 TDIs (VE and PD) 1 August 9th, 2014 11:41
catalytic converter tdimontana VW MKIII-A3/B4 TDIs 3 November 6th, 2010 18:37
Which Catalytic Converter to Buy? skrewdriver TDI 101 10 August 29th, 2007 13:25
96 TDI Passat, where to buy catalytic converter? mendes9 VW MKIII-A3/B4 TDIs 8 February 16th, 2005 19:21
Page generated in 0.20518 seconds with 13 queries
[Output: 75.29 Kb. compressed to 65.74 Kb. by saving 9.55 Kb. (12.69%)]
