Waiting on parts
While my suspension parts won't arrive until Friday, I decided to pull the bumper cover and front fenders since the two fenders need to be replaced anyway. I have the Tiwanese fenders and paid $103.28 for the two. Junkyards wanted $75 to $125 each for used fenders and most were damaged.
Here is accumulation of dirt and leaves behind the fender liners (sam both sides):
My two new fenders:
^^^^ First fender pulled: Yo really have to ask yourself what VW was thinking putting this foam piece inside the fender. Did they forget that it would get wet, hold moisture, and then rust out the fender?
Currently, I am pulling the bumper cover and have a stuck fastener that is one of the ones under the grill. The nutplate spins and looks like I will have to cut it off. Once the fenders are off and I have my suspension parts, I can get the bushings pressed in (try it myself) and install the LCA's, struts, ball joints, sway bar bushings and fenders. Paint will come later once I see what else needs done.
Once the front is in, then I will pull the rear shocks and see what the rear beam bushing looks like.
It's been nice here, with temps in the high 70's and low 80's. Wife is itching for me to start yard work (ugh).
