Puffin
In a recent post made in the Eastern Canada TDI Owners forum, I described how I partially cover my '03 Jetta's TDI engine water radiator with a piece of carpet when the present and the three to four day forecast temperatures are to remain at or below -15 Celsius (5 deg. Farenheit).
This proved quite useful during the January cold snap we had along the upper Eastern seaboard. Before using the carpet, I had no problems starting my '03 Jetta TDI wagon at -22 Celsius in the morning (using Shell's UltraDiesel) but it would take for ever for the engine to warm up and, to make matters more difficult, on long downhills, with the engine producing no power, the engine temperature would drop back from 90 to the far left side of the dial.
Opening up the centre grill in the front bumper to slide in a piece of carpet covering the lower 60% of the water radiator did solve the problem. Then engine temp remained bang on 90 even on long downhills and it did warm up faster after a cold early morning start.
My questions are: under unusually low winter temperatures, is it advisable to go as far as to plug up the inter-cooler air intake?
Also, what are the pifftalls, if any, of taking makeshift precautions to keep the engine warm during a sharp cold snap in the winter time?
Should the TDI engine's ECU nomally compensate for wide outside air temperature fluctuations? Could it be that on my car, the ECU was not doing its job properly before I inserted the blanket to cover the greater part of the water radiator?
I notice that recent models of pick-up truck sometimes wear a thermal cover on the front grill during cold winter days. Is that to say that TDIs should be operating with thermal covers as well, even though VW does not sell any as part of its OEM accessories?
Steve
Steve
