I have been experimenting to see what will remove the buildup on my old oil cooler. So far dishwasher cleaner and full strength radiator flush have failed. Im not knowledgeable on ph levels and that kind of thing. Im more of a believer that the coolant is getting too hot in the egr cooler causing the coolant to break down. It doesn't really look like aluminum corrosion in my opinion.767 nice work. Is there any consensus on an inexpensive pH test kit or effective flush? I have not experienced any issues (yet) at 76k miles and am thinking about multiple cooling system flushes with water when the freezing temps are gone. I'll probably run a day at a time (~140 miles, 3 hrs) with straight water and keep repeating until it runs clear. Wondering if adding some vinegar or lemon juice might help with dissolving deposits???
Never ever run non G12 or G13 coolants in a TDI.....767wrench,
I see in another post that you are running green coolant and not pink coolant.
Could there have been some pink left in the oil cooler when you switched to green?
Lol do some more reading around this forum there pro. All kinds of issues with the factory stuff. Hence the change to green organic acid and no more issuesNever ever run non G12 or G13 coolants in a TDI.....
Cooling system issues are never a thought when using G12 or G13.
Anyone that attempts to use a non G12 or non G13 coolant had better read this thread to see what they can look forward too!
VW is clear, mixing coolant types Will result in clogging of the engines cooling system aka the brown goo!
Just to get you caught up, all of the problems in this thread and the clogged heater core thread are with the FACTORY VW G12 and G13 coolants. Volkswagen clearly has a problem here, and it isn't with owners putting in the wrong coolant.Never ever run non G12 or G13 coolants in a TDI.....
