Steven715
Hello there, I wanted to help the community out with this problem I had with my 2011 passat I would think this will be the same for all of our passat / NMS
Below is the fault that I had on my passat it would not clear and since this did not affect anything I left it however as some of you know my passat went in for other work to be done and upon reading the paper work I noticed that they had put that they fitted a new parking break switch so I looked in the car and sure enough with the ignition on and when the parking break is on there is a yellow light lit. When I had the car I (2nd owner) it never lit up I did not know it had one until this was fixed.
So if you get this fault code it means that the little yellow light is not working and you need a new switch or do a repair on the light if you can.
Hope this helps someone.
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000024023
Coding: 0022167
Shop #: WSC 05311 000 00000
VCID: 354FC50D5CA2A7B6775-8060
1 Fault Found:
02442 - Function Lamp in Control Head
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 6
Fault Frequency: 14
Reset counter: 79
Mileage: 90619 km
Time Indication: 0
Date: 2025.14.01
Time: 15:02:42
Freeze Frame:
Voltage: 12.20 V
Count: 79
Speed: 0.0 km/h
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Steve.
Passat 1.6 TDI sport estate Bluemotion
Coding: 0022167
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 79
Mileage: 90619 km
Time Indication: 0
Date: 2025.14.01
Time: 15:02:42
Freeze Frame:
Voltage: 12.20 V
Count: 79
Speed: 0.0 km/h
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Steve.
