pleopard
Can someone with a Bentley manual tell me what the procedure is for using the bleed screw on top of the fuel filter canister. Or, if nothing is mentioned on the use of this screw, what is the proper procedure for replacing the fuel filter and checking for water?
When I asked if any water was found, I got quite a run around from a dealer before they finally said, "there was some, but it isn't a problem". The bleed screw has never been touched, so I'm not sure how one is expected to check for water.
