MrBigTruck
- Joined
- Aug 24, 2009
- Location
- Kansas, USA
- TDI
- 2000 Beetle, 2000 GTI ALH swap, 2006 Jetta, 2006 Jetta, 2008 Mercedes GL320 CDI
2000 NB, Front tire, driver's side. It's worn down pretty bad on the inside edge and looking at it i can see it sits at an angle with the top of the tire leaning in and the bottom of the tire sitting out. The passenger side is perfectly perpendicular to the ground and has no unusual wear. I rotate my tires every 5,000 miles, all front suspension components recently replaced except struts. Haven't done anything with my wheel bearings or axles either. Tie rod ends, ball joints, control arm bushings, sway bar bushings, upper strut mount and bearing all done. Got it aligned Struts are original with 161K on the car. I'm guessing struts. Will bad struts cause the tire to sit at an offset angle like that?
If it is struts, I've narrowed it down to Koni Reds or FSD's. Are the FSD's enough better to justify the extra dough? I drive 50 miles each way to work on 65-70MPH highways.
