CarlosVanDango
Hi after a bit more help, with my ASZ into Reliant Scimitar swap
i've decided the best way around the oil cooler fouling on the chassis leg problem is to space it out by about 3"-4"
what i want to do is make 2 plates one bolted to the block and one to the ally vw oil filter/cooler housing then join the 2 together with solid pipes welded in and drilled to make it all solid
my question is how many oil ways are there - it looks like 2 main ones (a higher and a lower one) and a pressure relief or non return valve of some sort on the housing, what would this need piping into and what is the purpose of it?
cheers
cheers
