FranticFrank
I read somewhere on here that a bad fuel filter can cause poor fuel mileage. Can somebody please explain how?
I'm currently getting 43.6 MPG on the interstate. It has gotten 58.6 MPG.
I've looked it over w/VagCom and can not see an issue. It has all new maintenance items except for the fuel filter. It has a new stat and is doing 92°C./197.6°F. The EGR is set to minimum. PVC is blocked off and is running a draft tube. The snow screen has been removed.
Thanks fwd for all of the help.
News flash! I found the IP timing off. The advance solenoid was running 29.6-30% and corrected it to 2.8 %.
