mandrake slink
2003 Jetta TDI. So, the A/C hasn't been working. In searching the related threads I saw the sticky about checking the radiator/condensor fan as well. I had the car off, key in on position, a/c selected on (lighted up switch), blower on 1 position. This is after it was driven home from work. I popped the hood and both fans in the front are not spinning. I then went to check the fuse number 16 in troubleshooting the A/C as well. As soon as I pulled the number 16 fuse, the passenger side fan started spinning and did so for five minutes. Is this to be expected? Also, a wire or wires on top of the battery case, 1 black and four red wires are shorted/overheated it seems (the black cable (50A) seems to be the overheating one and the red one right next to it is discolored) and melted the plastic on top of the casing. SEE PICS below. Boy, I could use some advice on where to proceed next. Thanks for any tidbits, shaming advice, helpful threads.... Have a good evening.
