CleverUserName
- Joined
- Oct 25, 2014
- Location
- NorCal
- TDI
- 2014 OZ Cruze CTD & 2010 JSW 6MT & 2017 GMC Canyon CCLB ATX 2.8 Duramax
So the way I understand it, high cetane fuels like GTL and HVO will advance injection timing compared to standard diesel #2 because combustion begins earlier during compression.
If you are using a high cetane fuel with 60-70 CN do you need to compensate for this to get an ideal spot when setting the injection timing in an ALH?
If so, how much does it need to be retarded? Is there a formula or standard for this?
