Old June 12th, 2019, 15:32   #1
Dkreisher
TDI(s): 1.9 BEW
Fuel Economy: 45 mpg
Default Need help with a p0101 code
OK so I have a question. I've had this annoying p0101 maf code for some time had been having a hard time figuring it out. Here's the list of what I've done so far with no results.
1. Replaced the turbo with a VNT17
2. Had vw replace the EGR system per bulletin
3. Replace maf
4. Replaced pigtail for maf connector
5. Stripped and checked the wiring under the battery.
6. Replaced the camshaft
7. Replaced the timing belt (because it was due).
8. Silicone all the intake piping thinking there was a leak.
9. Took it to the dealer and they could not figure it out.
What I'm finding is that at 50 to 53 g on the maf it faults out and goes to 0 if I hold the pedal steady and it bounces up and down but the intake pressure stays the same. At the dealer they said the camshaft sensor was not reading on their computer. Wondering if I should spend the money and replace it or could the adjustable cam timing be off. This has had me stumped for awhile. I have pictures of a few screen shots from my logger I'll try and load later tonight.
Thanks.
Dkreisher is offline   Reply With Quote
Old June 12th, 2019, 17:25   #2
STDOUBT
STDOUBT's Avatar
Welcome!
Are you using VCDS? If so, tried clearing the code?
Looks like you've covered the bases
http://wiki.ross-tech.com/wiki/index...5/P0101/000257
But there are more grounds than just the one under the battery:
http://web.mit.edu/dennis/www/vw/grounds.html
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR
STDOUBT is offline   Reply With Quote
Old June 13th, 2019, 07:49   #3
JB05
Fuel Economy: 43/41/40
Did you check all the boost pipes/hoses? I had the same P0101 DTC when the lower hose on the IC popped off.
JB05 is offline   Reply With Quote
Old June 13th, 2019, 08:10   #4
Tdijarhead
Did you put a cheap MAF (not a Bosch) in there?
Old June 13th, 2019, 16:24   #5
Dkreisher
TDI(s): 1.9 BEW
JB05, yeah I checked all that. Even siliconed all the pipes. I know it's bad but getting to the end of my rope.
Old June 13th, 2019, 16:27   #6
Dkreisher
TDI(s): 1.9 BEW
TDIjarhead, I did not get a Bosch but the problem did not get better or worse. The read out on my scanner shows the same issues on both.
Old June 13th, 2019, 16:48   #7
flee
flee's Avatar
Fuel Economy: 40-ish
So, you had MAF issue and swapped in a junk MAF and still have an issue? Go figure.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old June 13th, 2019, 17:14   #8
Tdijarhead
I think you’re going to have to eat the junk MAF and get a new Bosch. Lesson learned, junk parts taste terrible.
Old June 14th, 2019, 11:27   #9
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Some dumb stuff I thought about after reading your post and the Ross Tech wiki-
Clogged cat
Clogged air snorkel or filter
Wires/Connectors seem to pop up more and more as these cars get old.
Then there's the mention of mechanical problems. Maybe run a compression check.
Not mentioned is the vacuum hoses. Many devices use vacuum.
Old June 14th, 2019, 11:38   #10
SilverGhost
SilverGhost's Avatar
Just one more thing to consider - split in boost hose, cut/damaged seal on boost hose ends.
But from the air flow readings you posted I would pull the HO2 sensor out and see if they improve. As @BobnOH mentioned, a clogged cat will stop engine from breathing and MAF readings will drop off.
Jason
Old June 21st, 2019, 07:58   #11
Dkreisher
TDI(s): 1.9 BEW
Default pictures of the readings
So here are the pictures of what I see on my scanner (hopefully this works, not very forum savvy). Right at 50G/S on the MAF it drops out but then comes back. Ill order up a new Bosch MAF and see what happens. I did replace the cam position sensor and it does run a lot better. Turns out my old one had zero signal going to the ECM.
Clogged cat:
It's not that. It was removed, inspected, test pipe, then put back in. Same problem as before, even with the test pipe just more check engine lights.
Intake lines:
Those have all been removed and inspected, plus if it leaked due to a crack I would have a drop in the intake pressure. my pressure holds between 15-17psi on my gauge.
Air snorkel:
I even removed that as well as the snow screen thinking the same thing. No luck so went back on.
https://photos.google.com/photo/AF1Q...OAzGCDnjjdAb2x
https://photos.google.com/photo/AF1Q...WZ5z7omQTHtGm5
Old June 21st, 2019, 08:23   #12
Dkreisher
TDI(s): 1.9 BEW
Also I want to thank everyone for their input on this. This has been a long road for me and I appreciate all the help I can get.
Old June 21st, 2019, 09:03   #13
Dkreisher
TDI(s): 1.9 BEW
One thing was just brought up by a buddy of mine. Do you guys think it could possibly be in the ECU? I'd hate to replace it on a whim. I may leave that as a very last resort.
Old June 21st, 2019, 10:49   #14
BobnOH
not-a-mechanic
That's smart, they do fail, but it's rare.
code p0101 farfrumsanity VW MKV-A5 Golf/Jettas 7 September 15th, 2017 09:38
P0101 Code SBTY_Syndrome OBD Scanners 2 August 25th, 2016 14:33
P0101 code wetskier2000 VW MKIV-A4 TDIs (VE and PD) 19 September 6th, 2013 11:46
P0101 code again perrya VW MKV-A5 Golf/Jettas 1 August 14th, 2012 08:54
CEL code P0101 straw10 VW MKIV-A4 TDIs (VE and PD) 9 July 30th, 2012 15:46
Page generated in 0.16276 seconds with 12 queries
[Output: 117.75 Kb. compressed to 98.62 Kb. by saving 19.14 Kb. (16.25%)]
