deckerfl
Hi All,
I blew my turbo 2 years back, and after replaceing it have been chasing boost leaks , and still get CELs.
I was going into limp mode, but then I have replaced the post-turbo "S" pipe, which was split. still had boost leak. Then I did a boost leak test and found a split in the elbow pipe just before the Intake Flap. That cured my limp mode issues. and the Power is back but I still get P0101 "MAF Implausible signal" error, which throws a CEL after about 24 hours after clearing codes. Then after a few days I seem to get more errors.
P0299 "Underboost" Specified was 2295mBar, ACtual was 1866mBar at 2KRPM
and I get a P0128 Temp below control range error, but I think this is unrelated. I have to change the Coolant temp sensor in the back of the engine.
I have also changed the MAF and MAP sensors, but it didn't help.
I ran some logs of groups 01, 03 and 11, that I'll post up. I'm hoping it'll shed some light.
Thanks all....
Dan
The logs are hard to read, sorry, I did my best to line up the columns, Didn't see a way to cut and paste it so it'd keep the columns...
Oh and I have Rocket Chip Stage 2.
Thanks all....
Dan
