jeffreypurkis
Any input?
Eggs are good,but they are better with salt and pepper.Joe_Meehan said:The product is good.
Vitamin pills may be good also. If you need them use them if you don't they are a waste of money, just like most "good" automotive additives.
I would have to guess far more good additives are used when not needed as those used when they can do some good.
For $15 a liter, I will just buy ELF Solaris 507 at ($11.50) TDI Parts.joevat said:what about 5w40 lucas syntec oil on a PD? on the bottle it states that it exceeds vw 505.01
so is the oil just as good as elf DID? or motul?found this a canadian tire and was about $15/L.
Uhh, don't do that.joevat said:what about 5w40 lucas syntec oil on a PD? on the bottle it states that it exceeds vw 505.01
and why not?dhdenney said:Uhh, don't do that.
Brian already posted a link about their oil additives. I question their product and their marketing (did even before owning a TDI). Amsoil I can believe, Lucas not so much. As was said, good 505.01+ oils are available at half the cost of the Lucas.milehighassassin said:and why not?
Lucas Semi Syn 10W40 / is not 15 a quart it will probably perform as well as Delvac or DEO Schaeffers S9000 in a PD. Slightly thinner than DEO and thicker than Delvac or S9000. If you look there is a Ford SPEC and they could easily build a oil with the required additive package for Ford which is just like 505.01.Diesel Addict said:I've never seen a 5W-40 Lucas oil, but it more than likely would perform adequately in a PD, especially if it supposedly exceeds the 505.01 standard.
and where is this link? They seem to turn in good UOA's.dhdenney said:Brian already posted a link about their oil additives. I question their product and their marketing (did even before owning a TDI). Amsoil I can believe, Lucas not so much. As was said, good 505.01+ oils are available at half the cost of the Lucas.
See post #5.milehighassassin said:and where is this link? They seem to turn in good UOA's.
That is Schafers, but the other oil is not ELF.dhdenney said:See post #5.
Did you follow the link in post #5? The one to BITOG? The one that shows how Lucas oil additive defeats the anti-foaming agents in both Pennzoil 80W140 & Delo 400? Because that's what dhdenney is talking about - Lucas oil additives.milehighassassin said:So I still don't know what you are talking about.
Back on topic, I would personally stick with Power Service, Howes, Stanadyne, Primrose or FPPF fuel additives. I have used PS, Howes & Stanadyne and all seem to help in the areas they are designed for - I have never had a problem when running one of them at the recommended dose. I find Lucas' advertising disingenuous and misleading and would hesitate to purchase anything from them.dhdenney said:Brian already posted a link about their oil additives.
You are 100% correct, neither company has any oil on the 505.01 or 507.00 approved oils lists.burpod said:i also am not to sure if lucas "505.01" is on the vw approved list... i could be wrong but i don't think it is... (kinda like the amsoil "505.01")
Thank you. I didn't mean for my comments to derail this thread at all.scurvy said:Did you follow the link in post #5? The one to BITOG? The one that shows how Lucas oil additive defeats the anti-foaming agents in both Pennzoil 80W140 & Delo 400? Because that's what dhdenney is talking about - Lucas oil additives.
__. It may be all advertising, but PS, Stanadyne, Primrose and FPPF claim to add lubricity, boost cetane, handle water, clean fuel systems, and (for some formulations) lower the gel point. Howes and Lucas don't claim to do all this and appear to be aimed at the heavy-duty truck market. If I'm going to run an additive, I want it to "do everything". I have a feeling that Howes (especially) is great for lubricity and anti-gel but may not have much of a hit for the other effects. The "word on the board" seems to be that Lucas doesn't seem to do much positive in TDI's.scurvy said:(snip) Back on topic, I would personally stick with Power Service, Howes, Stanadyne, Primrose or FPPF fuel additives. (snip)
