Old September 17th, 2018, 22:49   #1
bigjake
Default Radio freezing up
Hey guys,
The other day, my radio froze. It lights up, but I can't do anything with it. Only the on/off button works. None of the knobs or buttons do anything. No sound, nothing. It won't work in tape, radio or CD mode. I pulled fuse 42 and left it out overnight. I plugged it back in the following morning and it worked for a few minutes before freezing up again. Any ideas?
bigjake is offline   Reply With Quote
Old September 20th, 2018, 13:04   #2
bigjake
This is the stock Monsoon radio in my mark 4 Jetta. Forgot to mention that in the op.
Old September 22nd, 2018, 14:05   #3
drucifer
Sounds like a new or new to you radio. Take a pic of the Vin if you get it from the junkyard.
drucifer is offline   Reply With Quote
Old September 23rd, 2018, 20:30   #4
wonneber
There's another fuse in the back of the radio.
If you do pull the radio to get to it you could also unplug the radio for several minutes.
Real long shot.
wonneber is offline   Reply With Quote
Old September 26th, 2018, 20:55   #5
bigjake
Soooooo it randomly started working again. I'll take it as an early toll of the death bell. I'll probably just pick up another unit when it gives up the ghost for good.
Thanks guys!
Old September 28th, 2018, 20:31   #6
wonneber
I searched for a clearance deal for years before I found a Kenwood with navigation and an optional Delirious satellite option in clearance at Best Buy.
It's a world of difference from the Monsoon.
Old November 22nd, 2018, 13:38   #7
bigjake
Ok, so the Monsoon kicked the bucked for good. Same symptoms in the original post. I would love to buy an aftermarket radio but I don't want to lose my steering wheel radio control capabilities. Does anyone know of a radio system where I can keep those? What about other accessories like wiring harnesses and mounting frames?
Also, if I decide to simplify things and buy a used Monsoon, I need the vin number of the original car the radio was in and I have to call the dealer with the vin to get the radio code to unlock, right?
Old November 22nd, 2018, 15:05   #8
drucifer
Just touch base with your local dealer to make sure they'll do it. Yes they are supposed to do it. Sometimes dealers just make stuff up just to squeeze the last dollar out of you.
Old November 22nd, 2018, 20:29   #9
wonneber
I think the steering wheel controls will work if it's wired in correctly.
Not positive but I think it uses the can bus to communicate.
Call Crutchfield or scour their web site. https://www.crutchfield.com
I got a 'power injector' for the antenna to keep using the antenna booster from them.
Old November 23rd, 2018, 07:47   #10
phantom1260
You can retain steering wheel controls if you buy the correct harness and modules in addition to your aftermarket headunit.
There may be other options but idatalink's Maestro RR is one of them. Crutchfield outlines it pretty well and its a relatively simple install process.
It all depends on how much you want to spend. Some people have been very satisfied with their Chinese android headunits.
I installed a kenwood DNX994S on mine.
phantom1260 is online now   Reply With Quote
Old November 23rd, 2018, 20:26   #11
wonneber
I have the Kenwood DNX571HD.
I'm very happy with it.
Don't have the wheel controls so I never hooked that up.
Old November 29th, 2018, 17:47   #12
drucifer
Also, if I decide to simplify things and buy a used Monsoon, I need the vin number of the original car the radio was in and I have to call the dealer with the vin to get the radio code to unlock, right?[/QUOTE]
code provided and free shipping
https://rover.ebay.com/rover/0/0/0?m...2F292141425930
a/c freezing up dyates442 VW MKVI-A6 Jetta Sedan (~ 2011+) 10 July 14th, 2014 15:31
Freezing air coming in around radio pparks1 VW Passat Family (NMS and B7) TDIs (2012+) 17 December 18th, 2013 19:10
So i know it's not below freezing yet... mjhandy Ontario 35 October 6th, 2010 16:52
09 TDI radio freezing smyb VW MKV-A5 Golf/Jettas 2 February 11th, 2009 14:50
door freezing Dragokatzov TDI 101 6 January 10th, 2006 04:59
Page generated in 0.17333 seconds with 13 queries
[Output: 101.75 Kb. compressed to 85.61 Kb. by saving 16.14 Kb. (15.86%)]
