TonganDiesel
- Joined
- Jan 28, 2004
- Location
- MI
- TDI
- 2000 Black 5 speed manual 234k miles, 2002 Black auto Jetta 309K miles
I have a 2001 Golf with 249K miles. I swapped in a 5 speed. I rebuilt the turbo because it was smoked, not much, on first and second gear. I rebuilt the turbo by replacing the CHRA with a Dorman cartridge from Rockauto, [It was still Chinese CHRA after I opened the box]. There was quite a bit of oil in the intercooler so I drain and clean it up. I also drilled a small hole under the intercooler and then plug it with a screw. I clean the intake manifold and EGR valve. I replaced the timing belt and replaced the fuel filter. These works were done in the past month. I drove the car for the first time last Friday. It runs great with good power. However, when I drive up on the ramp at the parking structure, I feel the engine surge at low RPM while I am on first gear. There was no surge at idle. It only surge at low RPM … like in first gear until I get out of the first gear. I scanned it and found code 17079 Quantity Adjuster N146 upper limit reached. The glow plug was blinking all the time after 10 second of the engine started.
I figure out the wiper arm of the N146 does not move to WOT at the turn of the key. The field 019 for the piston movement was 0.6v at the low end and 2.6v at high end. I decided to replace the pump.
The pump came from an unknow junk yard Beetle. When I picked it up, I survey the car and concluded the car fail due to a bent TB tensioner stud. I feel the pump is safe and operational.
After I replaced the pump, I tried for 30 minutes to start the engine but fail. I retard and advance the timing until it fired up at the advance position. As soon as it started, it surges to 1000 plus RPM then drop back to 900 RPM for a few seconds then it takes off to 3000 RPM where I was scare and turned the engine off. I tried several times to turn on the car but still have the same results of hitting the 3000 RPM. It was smoked like hell come from underneath of the car and between the engine and the firewall. It was dark so I did not see of the smoke comes from the tail pipe.
There is no error code of any kind. The 17079 code is now gone away and no more blinking glow plug light on the dash. I feel the pump fix the code 17079. I can’t figure out why the smoke and the surge and wishing you gives me suggestions on what to try next.
Thank you
Thank you
