kiwibru
- Joined
- Sep 21, 1999
- Location
- Distant island in WA. state
- TDI
- Golf 2-door, 2k Silver. Red RTDI now gone but not forgotten!
Recently purchased a GTD1756VRK from a EU distributor that is welded directly on to the OEM ALH exhaust manifold. It included an adaption that I don't trust in which the flexible braided oil line between the 2- hole gasket flange bolted on the turbo and the engine connection is replaced with a multi-layer silicone hose of the appropriate size, clamped on to the OEM connectors. From what I am reading silicone is not oil rated.
Does anyone know of appropriate adaptations using say AN connectors and braided s.s. oil line? Or, would the somewhat longer oil return line from a BHW engine work in this situation, i.e. it seems to have the same gasketed 2-hole flange and captured nut set up...
Apparently the OEM ALH oil return line is too short for this set up.
