89vr6
$2,000 obo
car is located just east of Cleveland, OH.
tan leather heated seats
BSM delete with ALH pump, new timing belt, and waterpump
bad: typical BHW needs cam,lifters,bearings causing car to go into limp mode due to low oil pressure
back story: bought the car not running,transmission has been rebuilt by buckeye transmission in parma, OH along with a new torque converter installed. ordered BSM delete and installed. finished putting the car back together and after starting the car it ran fine for about 5 minutes of idling, then once it was warm it lost oil pressure and went into limp mode, I immediately shut the car off. Pulled the oil pan found no issues, checked crank bearings which checked out good. checked the BSM module plug in the block and it was good. Pulled the valve cover to find that multiple cam lobes had excessive wear as well as the lifters.
