alireza57
My car is 1.9tdi touran 2009 7seater isit going to be under 2 rear seat or I best to look at service manualNot much VCDS can reliably tell you until you get the engine running, and I'm personally not sure disconnecting the injector harness helps much here... you want to know if it's firing.
Can you hear the in-tank fuel pump running for 5-10 seconds when you first turn the key to ON (may have to lift the back seat to hear it well)?
It's not uncommon for the in-tank pump to fail; the car will still run fine...for years...until the tandem pump loses prime for some reason.
Sent from my CLT-L09 using Tapatalk
