Area351
I just got done diagnosing a friend's car that THEY thought had a bad injector pump.
Based on what they said, I verified that there isn't anything wrong with the pump. It just seemed to be out of time.
Pulled the upper timing belt cover off and immediately saw the sprocket for the water pump sitting at a very weird angle relative to the belt. A quick poke with a long pry bar confirms that the shaft on the pump either broke, or the bearing is fubar.
At this point I know it's going to need at least a pump kit with new belt and tensioners. I don't know if these ALH engines are zero clearance or not, but what's my chances of NOT having a bunch of bent valves to go along with the existing problems?
Is there a way to quickly assess the situation and see if it's even worth trying to get away with just the pump, belt and timing?
I don't want to waste time and money on it only to find out the head has to come off too.
Any suggestions would be much appreciated.
Thanks in advance.
Thanks in advance.
