I tried to start my 2000 Golf TDI this morning and none of the dash lights came on. As well, the running lights were on even with the parking brake engaged. Worse still, the car didn't start, it would crank over, but no sputter or nothing. I've had the EGR plug up before and I got a little sputter when trying to crank it over. There is nothing in this case. Like if you disconnected the plugs in a gas engine. Based on the additional symptoms I think it is probably an electical problem, but why would a diesel crank over and not start if the EGR is not the problem?
Any suggestions would be of great help. I called the VW shop and the only mechanic there until Tuesday is an apprentice who was clueless.
Thanks,
JM
Thanks,
JM
