loganwolverine
I finished my 5 speed swap today and I think the neutral safety switch which is the white switch is bad. The car will start as long as the clutch isn't depressed. I took the switch out and checked it to find out the switch was open when the plunger is out and is closed when the plunger is depressed. Shouldn't it be the other way around?
