2006 2.0 Tdi Cam Belt Change??
johnjames1234
Ireland
golfvan
hi guys, a long with sorting out my caddy blue some problem, my GF mothers car is due its 1st timing belt change.. i have never changed belt on one of them before, but have changed other cam belts on different vehicles in the past, so do i need too look out for anythin? is there a how too on here? any advice would be great.
thanks john.
Lee_Taylor
Kent, England
Audi A3 1.4 COD
This is the procedure for the PD engine assuming yours is one and not the common rail engine....
http://pics.tdiclub.com/data/3419/BEW_timing_belt_procedure.pdf
There are a couple of tools you need. The crank locking tool I got from here...
http://www.justoffbase.co.uk/Crankshaft-Locking-Tool-VW-Sealey-VSE1706
They also have the tensioner tool. The cam locking pin I made myself out of some 4mm steel but they do have it as well. No doubt there are places in Ireland that have the stuff as well.
http://www.justoffbase.co.uk/Belt-Tension-Locking-Pins-VAG-Sealey-VSE1900
The bolts on the crank damper are really tight. It is fairly straightforward if you follow the pdf and are careful. I would recommend using new engine mounting bolts and changing the water pump while you have it apart as well.
