Daragorn
So I did an engine swap (1.9 AHU) into my vanagon this summer. It all went fairly smooth until start up. It would crank and put out a little smoke but would never take off. Through much troubleshooting, and trial and error, I finally discovered I could start the engine if I had the cold start injector/fuel shut off solenoid connection unplugged (obviously with the fuel shut off jumped to power). Plugging it back in would immediately kill the engine.
I've taken it down the road (up to 60km/h) with the cold start injector unplugged and it seems to have good acceleration and power like that but I've never driven this van with this engine so I don't know how is should feel.
I'd love if you all could give me some ideas on what else it might me or what else I should check out. Here's a list of everything relevant I can think of:
1. The engine fired up nicely before I pulled it out of the donor car. It was about 8 months between the last time it ran and when I tried to start it again.
2. Again, the engine starts and runs quite well with the cold start injector unplugged so I don't suspect that timing somehow went off track.
3. I have a new harness and ECU from Fastforward Automotive. Everything checks out good on it (I've tried a different ECU as well just to be sure). I have no reason to suspect anything in the ECU or wiring harness itself.
4. The Engine Speed Senor (or CPS) seems to check out good too. Within Spec. Reads what I'd expect on the OBDII.
5. The need lift sensor also seems good (within spec).
6. The coldstart injector is also within spec for ohm reading.
7. I don't have any codes.
So it seems like the problem is either the input to the cold start injector or the cold start injector itself. If anyone has ideas about how to diagnose or narrow this down further I would love to hear your thoughts. Thanks!
