Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old April 27th, 2018, 08:17   #1
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Default VW Still Believes In Diesels; Unveils New 2.0 TDI Mild Hybrid
Diesels are dying? Not so fast, says Volkswagen.
https://www.motor1.com/news/240543/v...gine-revealed/
Old April 27th, 2018, 09:10   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Finally!
-George Bernard Shaw
Old April 27th, 2018, 12:29   #3
tomo366
TDI Lifer
tomo366's Avatar
https://www.cnet.com/roadshow/news/v...CAD-16-10abc4e
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old May 7th, 2018, 06:41   #4
kjclow
Better news if it can find it's way across the permanent puddle. Wasn't the diesel hybrid part of the original concept behind the Atlas?
Old May 7th, 2018, 08:29   #5
tadawson
Now if someone will come up with an 'electric delete' for it . . . :-) :-)
tadawson is offline   Reply With Quote
Old May 7th, 2018, 16:13   #6
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Then it won't start or charge because it replaces the function of the starter and alternator. You could put in an older bellhousing and conventional starter and maybe fit an accessory bracket from an older car with a conventional alternator, but who knows if the ring gear teeth on the flywheel will still exist...
Old May 7th, 2018, 16:23   #7
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I'm all for a BAS system, although I question the utility of so much work being expended just to turn a non-firing engine in the 48V systems that have an e-drive mode (this TDI mild hybrid will not so I digress, but the 48V one used in the V6 TDI apparently will). More elegant would be to have the e-motor/generator in the bellhousing replacing/augmenting the clutch or torque converter.
I thought of doing a poor-man's regenerative retarder using a high-amp 12V alternator that is common in competition sound system circles. I'd add a bank of 18-20V li-ion batteries but nominally maintaining a ~60% SoC and standard 14.4V voltage. When I'm coasting or press a steering wheel button, the alternator would kick into full 18V and full amperage (300A is not uncommon), giving me 5.4 kW of retarding power that charges up the batteries. I can then descend down pretty decent grades without touching the brakes and recuperating the electrical energy as a bonus.
Old May 9th, 2018, 04:11   #8
LRTDI
Aircraft starter motors are also alternators generating power. Ram is using a similar system for their new 2019 1500 Hybrids. The technology is coming.
LRTDI is offline   Reply With Quote
Old May 9th, 2018, 06:21   #9
kjclow
For 2019, the hybrid option won't be available on the ecodiesel. At least that's what the current press is saying.
Old May 10th, 2018, 17:45   #10
[486]
TDI(s): 02 golf ALH
I've thought on it too, with some big fat supercapacitors in the mix to suck up the fast spikes of power needed and produced. Some companies make wheel motors that bolt on, could be tossed onto the rear axle real easy.
Finally decided that nah, too much effort.
Old May 21st, 2018, 06:40   #11
cheezy
cheezy's Avatar
Fuel Economy: NB-52.6, B4-37 city on 2 yo fuel!?
Yup, the diesel hybrid that pulls 60-125 mpg, with less emissions in the promise? Holy crap let's go already...You know GM won't do it.
cheezy is offline   Reply With Quote
Concept Car: VW unveils Diesel Electric Hybrid Twin-Up! Terrific-In-Tahoma TDI News/Tech 19 December 8th, 2013 17:23
VW looking at a "mild hybrid Jetta" for California candrews4tdi General VW Discussion 0 January 31st, 2007 11:32
Auto supplier believes in diesels V TDI (Diesel) Emissions 0 February 15th, 2005 07:13
Auto supplier believes in diesels !!! (link ) HAMMERFALL General VW Discussion 0 February 15th, 2005 06:01
VW Brings Diesel Mild-Hybrid Concept to Shanghai BrandonH TDI News/Tech 0 October 14th, 2004 13:43
Page generated in 0.16671 seconds with 12 queries
[Output: 106.57 Kb. compressed to 90.28 Kb. by saving 16.29 Kb. (15.29%)]
