cal71919
I may go see a 03' tdi golf later and was curious as to how long an oem injector pump would last. The car was given up to an auto shop in town when the owner decided the repair cost were more than the value of the car. The shop refurbished the cylinder head, replaced the timing belt, and water pump. The car is very clean, inside and out. As for the milage, 502k. the shop doesn't have any knowledge of when or if the injector pump has been replaced so should I just assume its the original pump or is there no way a pump would last that long? Obviously, thats going to be my angle to bargain with but would there be a date same or code on the pump? Honestly, I only need to get a year or so out of it but I'd like to be able to get something out of it then. Blue book puts it between 1k-2600. Is that accurate? I appreciate any help, as I'm eager to learn.
