Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Motorsports
TDI Motorsports This section is dedicated to the folks who push the TDI to the absolute limit racing. Topics should include articles about TDIs in the SCCA ProRally Series, Drag Racing, AutoCross and any other events that include TDIs.
Old August 4th, 2018, 16:19   #1
jim k
Default compack diesel
need some help in designing a cam for a pro stock mini rod with a 1.9 tdi alh 81.5mm bore ,95.5mm stroke, ported and polished head with over size valves. How high of rpm can i get out of this type of a engine build? This engine build is new to me. The diesel engine class is new to our club. Looking for advice and help so we are starting out in the right direction. Located in the central USA Tabor South Dakota
jim k is offline   Reply With Quote
Old August 8th, 2018, 21:50   #2
Twitch
If you upgrade the valve springs the alh can rev to 7k safely but would need a lot of fuel up there and a good size turbo to make it worth it to rev it passed 5-5.5k and the vibrations at that rpm level you will need a fluid dampner and would look at upgraded rods it will take a lot of money to make it rev out the diesel is better to use the low end torque they were designed for
Twitch is online now   Reply With Quote
Old August 9th, 2018, 09:06   #3
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Hopefully, TDIMeister will see this thread.
-George Bernard Shaw
Old August 12th, 2018, 22:42   #4
3L3M3NT
3L3M3NT's Avatar
You're probably going have more replies by posting your question in the Power Enhancement sub-forum than you are here. Power Enhancements
But to answer your question, quite a few people run their ALH TDI up to 6,000 rpm range and I thought I read someone going as high as 6,500 rpm, but don't quote me on that.
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is online now   Reply With Quote
Old August 13th, 2018, 05:42   #5
Twitch
Theres a video of someone floating around on youtube and think has a thread on here that fully built a alh and free reved it to 9k and engine was fine so depending how deep your pockets are can go pretty high but more reasonable would be 6500-7k
Diesel emission NOx with diesel and Bio-Diesel redrocketTDI TDI (Diesel) Emissions 25 July 29th, 2016 19:06
Mk1 Diesel Rabbit Pick up + 4 door diesel + Td motor swap vwsnaps TDI Cars for Sale/Wanted 3 June 8th, 2014 17:34
Toureg = MG diesel = Cayenne diesel = Jeep GC diesel? kmmcdonald VW Touareg TDIs 4 September 23rd, 2013 18:33
2012 gas jetta vs diesel jetta vs diesel golfwagon vs diesel passat HAVE JETTA WILL TRAVEL TDI 101 10 August 21st, 2012 14:56
Page generated in 0.16652 seconds with 13 queries
[Output: 67.87 Kb. compressed to 60.04 Kb. by saving 7.83 Kb. (11.54%)]
