whizznbyu
- Joined
- Jul 11, 2006
- Location
- Waxhaw, NC
- TDI
- 2015 Golf Sportwagen 6 speed manual. B5 died at 302k miles.
Is it OK to put Liqui Moly SO2 in a Q7 TDI? Is this going to mess up the DPF?
. I don't know but maybe if you tell us why you want to use that stuff, someone may be able to give you are better answer.Is it OK to put Liqui Moly SO2 in a Q7 TDI? Is this going to mess up the DPF?
Our engines require low SAPS (Sulfated Ash, Phosphorous Sulfur) motor oil. Is this additive guaranteed to be low in ash and phosphorous, & sulfur? If not, it could damage and/or shorten the life of your emissions system components. This could get to be very expensive. The correct oil is a very good specially blended synthetic motor oil. Make sure you always use the correct oil and don't worry about additives.
Have Fun!
Don
