jdulle
If the Bosch AL0723X should be avoided, what is the best alternator as a replacement for an original 120 amp alternator (96 b4 tdi)?
I believe that all Mk3 cars came with the clutched pulley from the factory, every one I've seen has one.I don't believe either alternator originally had a clutched pulley, but they're now available. And yes, they're the same alternator.
My first Mk3 had a clutched pulley (non-clutching anymore, until I replaced it). I highly doubt any of the P.O.'s had changed the fixed pulley to a clutched, or followed a mechanic's advice to do so. That leads me to believe it was factory (1998).I believe that all Mk3 cars came with the clutched pulley from the factory, every one I've seen has one.
Sorry for the delay. The confusion may be due to two things: errant label, and the supposed clutched pulley causing the failure. Here are some comparison photos.I pulled two 723X’s off of two different, ‘02 ALH’s…
