Dimitri16V said:
the problem with this theory is the failed PDs we have seen have trashed VALVE lifters, the injector lobe assembly is just fine.
Most 505.01 are not even true sysnthetics and their additive package is nothing to brag about.
__. Yeah, Dim, and the theory has always been that the problem goes back to the fact that -- to get the injector lobe in there -- VW had to reduce the width of the valve/cam lobe. These are significantly narrower than the ones on the ALH (and earlier) VW diesels. All the force in lifting that valve is being concentrated on a smaller area on the lifter (and the cam, too, for that matter). So the problem isn't the injector lobe, it's the fact that the injector lobe is *there*, crowding the space that the valve train needs.
__. And I agree that 505.01 oils don't look like much to me, but the one thing that they
do is to cover that severe-localized-compression-loading regime. And I'm guessing that good-quality, diesel rated synthetic oils (Delvac/Turbo Truck Diesel, etc.) will be just fine. The problem is that there's pretty good info that using 505.01 will protect your engine reasonably well. I don't mind anyone experimenting with his own engine, but to really come up with results, you'd need to have a comprehensively managed test fleet with proper analysis at the end of the test period. At least that's the only thing that would make me feel comfortable (if I needed 505.01 oil, that is). And I think that it's most unfair for anyone to look at the numbers on an oil analysis and recommend to a newbie that he run anything but 505.01 -- if you wanna gamble fine, but leading someone into gambling when you don't really know where you're leading them is really unfair.
__. As I've said before; there seem to be three kinds of oils out there:
1) Oils that are recognized to protect the engine (i.e. 505.01),
2) Oils that will protect the engine just fine (but aren't proven to do so), and
3) Oils that won't protect the engine.
__. The problem is that none of us has the knowledge and resources to distinguish between 2) and 3). We can try, but we're really just guessing. So, you can take a stab in the dark and hope (and risk major engine damage), or follow the recommendation. I know which
*I'd* do, if I had an engine that needed 505.01.
