jdeserio
Hi guys, I've been hesitant to sell my Golf, but after moving closer to town, I really don't need a second car and especially a diesel.
$4,000
Here are the specs:
https://imgur.com/a/RfJcD
189,000 miles.
Black cloth interior.
Moonroof.
I average 45MPG. 70% highway.
Malone Stage 2
VR6/G60 Clutch
EGR delete/Block off plate (Darkside)
11mm fuel pump (from auto).
New Timing Belt Done 10,000 miles ago by a local diesel mechanic. Then was VAG com adjusted by Diesel Dubs.
Bosio.357 injectors
New General RT43 Altimax all season tires. (I love em)
New glass lenses.
Bilstein HD Struts
Tow Hitch
GTI Tails
Battery replaced last year.
Fresh oil change.
The Bad:
Roof rack not included.(Already sold it)
AC doesn't work. No leaks, compressor won't kick on. Could be a fuse.
Struts are starting to leak fluid. Car still drives great.
Tie rods need replaced soon ( joint is almost deteriorated)
Trunk latch (dowel rod) broken. Trunk needs new latch parts and interior cover.
Practically no rust, but starting to bubble slightly on right fender/door.
Burns a pretty average amount of oil, about 1 quart ever 5,000 miles at the most.
Here are some older pics, but I will update the thread with new pics this weekend!
$4,000
Here are the specs:
189,000 miles.
Moonroof.
Malone Stage 2
VR6/G60 Clutch
Bosio.357 injectors
New glass lenses.
Bilstein HD Struts
Tow Hitch
GTI Tails
Fresh oil change.
The Bad:
