calimustang
- Joined
- May 17, 2010
- Location
- Central FL
- TDI
- 2011 JSW DSG (buyback, RIP), 2014 JSW TDI, 2015 Passat TDI, 2013 Jetta TDI.
Hello,
I am also an 2011 JSW owner, happy to report almost 161k flawlessly miles.
only common issue are RCV. They replaced original compressor instead by warranty. Now I'm on 3rd compressor, my fault kinda on the 2nd one so it's excused due to my procrastination and FL heat exhausted the compressor.
So far what replaces are tires, I'm on the 3rd set with new steelies now. Discarded my OEM 16" bioline wheels, they are bent easily, one local shop bent one and caused others to have issues down the road so i got rid of them for steelies because I drive a lot and there are some rough roads and i got tired of vibrations.
still on original brakes as in rotors and pads, when i replaced wheels, pads showed about 50% thickness at 152k. I believe i can pass 200k on the set.
Original DPF, Alternator, Suspension.
replaced one glowplug so far.
Share yours also please.
