Moving the wire from A28 to C47 is required. I think moving the wire that was in C47 to A28 is only required if you have halogens. In the default NA wiring, pin A28 powers the driver's side reverse and pin C47 powers the passenger DRL.
When you change the lighting code to 02 the pin at A28 powers the passenger DRL and the pin at C47 powers the rear fog.
This post was the key:
http://forums.vwvortex.com/showthre...9-Wiring-of-few-common-add-ons&highlight=j519
Maloosheck was confused about the left reverse and right DRL sharing the same pin. It turns out they do; what the pin powers is changed by the coding in byte 18.
The is obviously halogen only. Dana at Ross-Tech has a xenon GTI and confirmed that the wire from pin C47 does go to the passenger headlight, but there's no pin at the headlight side of the harness because the xenons are used as the DRL's.
