Last Friday, I got my my 5 speed swapped for a 6 speed on my 03 TDI.
The tranny code is ERF and was just rebuilt w/ an Peloquin LSD added to it.
The clutch his a DC stage IV+, has a high performance dual full faced feramic lined disk (feramic linings on both sides); Rated for 575 lb/feet of torque.
The flywheel is lightened to 12 lbs and has been balanced
My problem:
I got this way strange super LOUD chatter. Nothing like I ever heard before. I am used to lightened SMF chatter but this seems WAY different and super LOUD. http://www.youtube.com/watch?v=wy0Q1V0Py68
When I first start it and release the clutch, it sounds like no chatter I have ever heard.. sounds like the whole frickin clutch is coming apart. Frickin LOUD. Can't even hear the engine running. Like it's rubbing or something .. I mean it is fricking SCARY!! Then I pump the clutch pedal a couple times and release the clutch and it totally goes away ... it sounds just like if the clutch was pushed in on a normal lightened SMF set up. Then I leave it.. and the chatter starts to come back slowly. It gets louder and louder and then it gets wayyyy frickin LOUD again like before, and it sounds like it's coming apart. W T F ?
So it's super frickin loud... pump the clutch cpl times and to goes away completely. I release the clutch and Can't head any chatter at all?
Has anybody had this kind of chatter happening in your 6 speed when you put an new HP clutch ?
Any thought on how to remedy?
My problem:
