cygnus
ive got a bew wagon ,had this issue for quite a while
a jarring jerking feeling through the car when letting off the pedal
seems worse at higher speeds. My other diesels do not do this
I have to release the last bit of the pedal very slowly to avoid it.
the front end has been refreshed apart from sway links an inner tie rods
first thought was dogbone. the dogbone and axels play seem to match my other bew wagon.Both engines seem to move about the same under load.
I replaced the transmission side mount and dogbone with used ones i had and it made no difference.
Im wondering if i should swap in some used axels i have to rule those out.
Is there any chance fueling could be causing this. if so would i check injection
quality?
thanks
quality?
thanks
