GrampaJ
Well after doing some work (timing belt, head rebuild etc. ) on my TDI I went to start it and I am immobilized. The car was down for over a week and battery voltage showed 12.4 on scangauge. I have disconnected the battery and hooked the cables together overnight and then turned on the key and let it sit for at least an hour and light still flashing. Battery now fully charged. I have googled and read everything I can to try and learn as much as I could and hooked up VCDS and pulled the following codes. There are no engine codes but a bunch in the instrument section..,
01176 key signal too low
01312 powertrain data bus faulty init.
01314
01316
01321
01315
2001 Jetta TDI with immo. 2 system but I do not have the SKC code unless it is hidden somewhere. I am hoping to have it chipped this week (and delete the immobilizer) but I need to somehow get it running to get there (250 miles). I am making a 1200 mile trip so I can get to my sons birthday so that puts pressure on me to get this running for Thurs. so we have a few days to make it happen but unfortunately these immobilizers are not easy to get around. I don't want to go to a dealer especially since the tune can easily solve the problem and for a fraction of the price.
I have pulled the lock and checked the immobilizer ring wires/connection and they seem fine and I did an ohm test and it tests just fine.
By the way... to muddy the waters there is an remote starter installed and they used a coil of wire wrapped around the immobilizer ring and who knows how that was hooked up but it obviously did work to fool the ECU at least for short periods of time. I never had the remote for it and I have left it there simply because I did not want to cause myself the type of grief that I am having now by trying to unhook it so it has been there for years with no ill effects. However that coil obviously has been used to send the correct signal to the ECU for at least a timed period used to warm the vehicle up. I wonder if there is any way that that could could be used to start the car but of course the down side is that if it quit the car would be immobilized... arg... modern technology. If I had the time I would send the ecu out and have it tuned and flashed to remove the immobilizer but I would not make it to see my boys in Canada so I would hate for that to happen. Any ideas that I could try? Are there any tests in the cluster that I could do? Thanks for any ideas.
Grampa"J"
01314
01316
01321
01315
Grampa"J"
