Can you guys tell me what you guys think is going on? Bad maf, something up with the turbo, maybe both? Car is 5spd converted alh.
Run number 1. As you can see the maf appears to be out of whack at idle. Went limp mode at like 3000rpm 4th gear no CEL.
Pulled over and restarted, which fixed the limp mode. Run number 2. Limp mode again same rpm/gear this time resulted in a cel with overboost intermittent code.
Let me know what you guys think because I don't have a clue.
