LarrE
Vehicle is a 2003 TDI Beetle w/manual trans and all the options
The short version
Intermittent charging light, battery mysteriously died, replaced battery, discovered charging light only comes on at higher RPMs (voltage regulator overcharged battery?), family member replaced alternator with rebuilt unit from O'Reilly, battery discharged after one day stranding wife, talked O'Reilly into a new battery.
Disclaimer: I had a busy week at work so I trusted others to do everything prudently and correctly.
Now that I'm becoming more intimate with this problem - i.e. Reading manual and TDI Forums and enlisting the help of a trained mechanic friend - I'm trying to rule out other possibilities before going to all the trouble of replacing the alternator again. Here's what I know:
1. Battery light no longer goes on when key is on.
2. When car is running the volt meter is under 12 volts and doesn't rise when rpms go up.
3. Cable coming from fuse block to POS terminal is bent funny and could be suspect.
4. My Autel code reader doesn't come up with any faults.
I'm open to any suggestions.
The short version
