rtgjetta
If so, it appears the two o-rings are the same size. Does it matter which goes on first? Also, to prime the filter can you cycle from off to run position without starting to get fuel to the filter using the fuel pump? If so here how many cycles would be oppropriate?
TIA,
Rob
TIA,
Rob
