jerrymelons
Hi, guys! I just purchased a 2000 Jetta TDI with a 5 speed. Now when I purchased the car, it had a condition where whenever you were in low revs you had no power until you stomped on the throttle and the car would take off! so I replaced the MAF sensor in hopes that this would help, as I unplugged the maf and had no problems except lower power of course. So fast forward to yesterday. I receive my new MAF sensor, install, and go for a drive. Car runs better than it has since i first got it, turbo works well and has plenty of power! get home, and pop the hood, and see one of the vaccum tees to my boost solenoid (pretty sure that's what it was) had broken! So I replace it then have to go to the store, and it starts sputtering in low revs from about 1K-2K bucking, sputtering and has no power. then once it gets to 2K it takes off and the turbo kicks in! It sometimes does it when in neutral as well, under no load. Now The timing belt and water pump was recently replaced, and timing was confirmed good at a shop with vcds. Cam is good, New air filter, and all vacuum lines were replaced. I've inserted a short video clip I took on the way to work this morning. I have no codes as well. Any suggestions are appreciated! Next on the list is testing the turbo actuator, as it does move, but I have no idea if it holds vacuum. Also a new fuel filter.
https://youtu.be/Zd__ljGfa0A
